| I am and I believe I am as clear as I can possibly be. I even posted a video to even help yet no one has even took time to view it. I have done ever check except to get the number off the ECU for Cjw3, which I will do here shortly as I get fully awake.. So here is a check list that I have done already maybe this will HELP.. Injectors - CHECK Coils - CHECK TPS - CHECK Temp Sensor - CHECK Fuel Filter - CHECK ( REPLACED ) Fuel Pressure - CHECK ECU CODES - CHECK ( Code 55 ) All of those are fine.. As for the gauge I know its suppose to register 0.. But when you start the car and its on -10 and on the throttle you go to 0 somethings busted, not any time will I go + on the guage..
